wellcraft w/l6 292 alpha 1
fishdog4449
Hey guys im lookin at a possible project, '72 v20 steplift wellcraft from a guy whos sick of restoring it, hull an trailer in great shape. He bought a brand new 292 L6 crate motor (original was a 250), new bellows and gaskets, and a new lower unit. He installed the motor and says it lines up, but the gimbal bearing needs aligned, manifolds need put back on, and lower unit needs re-installed. I'm very good with outboards but never touched an I/O, how much of a project would this be to get it running. I really like the boat and can get it for pretty cheap. Also I've never heard of a 292 must just be a 250 with a longer stroke maybe?
Thanks in advance guys!!
Re: wellcraft w/l6 292 alpha 1
Ayuh,... I could probably button it up in a Weekend,... Your results may vary...
The 292 is the big sister of the 250...
The stroke is longer,+ the head sets slightly higher, but it shouldn't create much of a fitment issue...
fishdog4449
cool...I'll have all summer to do this but would like to get it water ready at least in a semi timely manner!! any special tools for the gimbal alignment?
Ayuh,... The Alignment Tool of course...
An Alignment Bar search will find you the dimensions to build 1...
Bt Doctur
the 292 needs wet exaust hose to replace the rubber one. 292 is about 2 inches taller
starsnstripers
I fooled around a little and have a 292 sitting here. there's something about the front mount from the 250 not fitting the 292 because of the harmonic balencer difference. Check that out before you jump. ;)
starsnstripers
Look up the part#s if you can for a front motor mount for the 292 mercruiser and compare it to a 165 (250) L6 #they only used it for one year 1969 I believe. I think the front mount on the 250 doesn't clear the bigger harmonic balencer on the 292.
fishdog4449
Here are some pictures. My dad thinks im crazy for getting rid of a perfectly restored running boat and going to work that needs work but i don't think so!!
ziggy
i wish you nothing but the best luck. but i was (am) under the impression that a 292 was always fitted to a mercruiser II drive. so fitting it to anything other than that would be a challenge. i only understand this from reading so i could be totally off base too.
let us know if ya work it out.
fishdog4449
I haven't been able to find much info on the 292. The owner said he installed the engine and it matched up, but I will have to clarify this to be sure. I believe that the bolt pattern is probably the same as its the same block, but taller, but maybe a longer exhaust (pipe, tube?) after the elbow.
Sorry I don't know much about I/Os at all I'm going to have to buy the manual for the drive if i get this boat.
