daraghcummins
Thread starter- Joined
- Mar 17, 2010
- 17
Help!
Hello all can anyone help me with the following??
I had to replace 1 cyclinder number 3 in my yamaha v4 2-Stroke 115 1986. It was bought this way as it overheated. All the hard work is done but it wont run??? Spark is ruled out and it is also getting healthy fuel.
Compression.... I have 105 on all other 3 cylinders and 93 PSI on number 3 the one causing all the trouble. This cylinder was running after i replaced the piston and is now not its very od! Dont no what to do with it and the summer is coming. I did not rebore the cylinder just but a standard size back in as no damage was caused to the walls of the cylinder however it did require a hoaning. Its basically runnig fine now on 1 2 and 4 and number 3 is kicking in and out.
Thanks in advance
Daragh - Ireland.
Thanks in advance
Daragh - Ireland.
