avimgod
Thread starter- Joined
- Nov 22, 2008
- 90
So, I finally got around to digging into my floor to get a better look at the soft spot in the floor...
I was able to pull it apart with my hand.
Water is resting on TOP of the fuel tank... I will suck it out with my shop vac eventually... BUT
it appears someone previously decided to cut out a section of the floor, and when putting it back together used PT 3/8 plywood rather than marine grade, AND didn't use any resin to seal the wood...
You can see where the PT ends, and the glassed wood still is...
Not sure WTF they were thinking...
All the wood UNDER the repair was also PT dimensional lumber, and rotten even worse than the flooring was.
I will be removing the entire floor, all the seats, and re-doing everything, only re-doing it the RIGHT way this time, found a good source of AB rated exterior 7ply 3/4 plywood, $33 a sheet, and will be using 4-5 sheets total, epoxy, 2 oz CSM, 1.5 oz woven, and PLENTY of new good wood...
I also took pics of the Captains seat that came with the boat, I will be adding a second one of these on the other side, making the rear a full bench...
And the NEW (03 repower) 35 hour or so drivetrain is AWESOME!
So the effort has begun... I will keep this going as long as things keep going...
