took my boat out for a shakedown run with the new motor, a 56 30hp johnson. after figuring out I hooked the air and fuel lines up backwards ( had a leak, gotta love old hoses) it started right up. After running for about 20 minutes and adjusting the mix to get it running decently, we headed out to the lake. 3 different times it felt like i hit something at 3/4-WOT, just a quick jolt from the motor but I know I was in 20 feet of water in a muddy bottom lake. Also at idle and in neutral, it would do the same random cough/jolt, sometimes even die. In gear, it'll idle all day long and not hickup once. Anyone have any idea on whats going on here? I put new plugs in it before we went out and also had fresh gas in the tank.
Thank you for the help.
Also, on a 14' fiberglass boat, how do you think this motor should perform?
The boat was empty, 2 people (160 lbs and 200 lbs) and it was a dog to get on plane and seemed like it should have some more throttle to it. Linkages are adjusted correctly. I forgot my gps but I'd say I never broke 20 mph
