FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
i had a 5.5 and i seem to remember you had to take off powerhead.but ive had so many of those little guys maybe im getting it confused with the 56 5.5 or were they the same procedure?
Yep, the disconnect is underneath the powerhead. Gotta remove it to get to it. Not nearly as bad as it sounds, though. Just keep track of the bits on top of the driveshaft - they need to go back on in the same order they came off...
- Scott
Powerhead must come off. Seven screws under the pan. Disconnect throttle arm and fuel line and off she goes. Under that is a couple of square nuts that hold the shift rod in place. Disconnect that. Remove 4 screws on lower unit and it should drop.
As the other poster said, replace base gasket (313065 or 18-2901) and crankcase seal (303355 or 18-2892). Both of those items are usually less than $5.
Yep, 7 bolts for the powerhead, then the two nuts that hold the shift-shaft to the shift-lever linkage. Pwerhead base gasket may be shot, so be prepared with replacement: Sierra #18-2901 or OMC#313065. Also, replace the cork gasket, and probably the o-ring, on the carbon bearing/driveshaft seal: OMC#303355. The cork seal shows as a carb part on some sites, but that is the right part number.
