1987 cobra outdrive help
onefishookk
Just drained the oil out of my omc cobra outdrive and its very milky. what can I do now what do I look at? maybe the seal at the prop or mabe the billows? water is getting somewhere. any ideas.
thanks
Leonard
CheapboatKev
Re: 1987 cobra outdrive help
Welcome Aboard..
If you post this in the I/O Forum, you'll get a better response.
Could be almost anything, You will probably want to pressure test your OD to see if she is watertight..
Good luck
Bob Gilvary
Only milky? Could be as easy as the gaskets around the fill/drain screws.
zbnutcase
Cobras really like to leak at the water pump shaft seal, first place i'd check when pressure/vacuum testing it. 'nutcase
Juniinc
I had some milky oil in my cobra too.
found out my drive bellows was leaking, also had a fishing lined prop seal.
