engine growling
brandonw206
i recently replaced the rotted motor supports on the side of the boats i installed the engine and outdrive back in it after i installed them and started the motor it made a growling noise from the back of the motor
Don S
Re: engine growling
Not a mention of what engine, outdrive, manufacturer, or year or anything to tell us what you are working on, but you want to know what the problem is.
Well, it's a bad bearing, probably, or maybe, or it could be something else.
Re: engine growling
Ayuh,... Sounds like you did it wrong...
cr2k
Re: engine growling
Did you align the engine? If not I hope you did not do too much damage to the coupler. They are $200+ and drive and engine removal to replace.
Rocky_Road
Re: engine growling
If this is an Alpha drive, you could easily pull the outdrive off...BRIEFLY run the engine...and see if the noise has gone away.
If the noise disappears, then you will know that it could be the alignment, or a gimbal bearing, or a u-joint, or....
Don S
Re: engine growling
Until he tells us what he's working on, everyone is just taking a bunch of WAG's based on hopes.
I mean, giving prices for parts and what it takes to do it, when you don't even know what he has. COME ON !!!!!
Wait for his reply with what he has, then make your comments instead of cluttering the post with Merc info if he has an OMC stringer, or a Volvo or ...........
brandonw206
Re: engine growling
sorry if forgot to put what it is it is on a 1990 welcraft its a mercruiser 4.3 alpha one
Don S
Re: engine growling
Pull the outdrive, check the alignment, and check for water in the bellows, and/or rust on the ujoints & gimbal bearing.
You may have also damage the coupler if you raised the engine too high for too long. with the drive still on while you fixed the stringers.
brandonw206
Re: engine growling
here is a little more info the motor mount were rotted out when i bought the boat the guy said he ran the boat last summer with them in that condition i felt the u joints and greased them and they appeared to be fine i started the motor without the outdrive on their and the noise was gone i only lined up the engine by eye
Don S
Re: engine growling
Did you check everything before and when you put it back?
Please understand, We weren't there, so have no idea what you have or have not done, or what you have done if it was done correctly or not.
brandonw206
Re: engine growling
thank you guys for everything i am going to order an alignment tool and replace the gimbal bearing and then go from their
Don S
Re: engine growling
Why would you replace the gimbal bearing if it is not bad or if it's not the problem.
Sounds like you want to be a "Throw parts at it till it works" type of guy then complain about the cost.
Start looking for the problem, not just a couple possibilities on a forum. Pull the drive, look for water, turn the gimbal bearing by hand, if it's perfectly smooth it's NOT your problem. Check the ujoints, alignment, all that stuff. BEFORE you order parts.
Order what you need, not what is suggested as a Possible cause of your growling noise.
fat fanny
Re: engine growling
Good rule of thumb especially here is to do the most inexspensive things 1st TROUBLESHOOT! after reading the pertinent information out of your manual free up in the stickies. Good luck!
