red_chaser
Thread starter- Joined
- Jan 26, 2010
- 62
i finally completed all the maintenance items to the engine..
turned it on with the key and she started right up with no problems. but when it did start, the idle speed was way too high.
after staring at the levers and screws, i decided to turn the black knob (#1). after that the idle went even higher so i turned it the other way but that didn't make it go down at all.
i found out that the very top lever (#2) controlled the idle. i turned the screw (#3) to back out the lever (#2). after i did that, the engine did not want to start at all. i tried to place everything back like it was but it still did not want to turn on. i didn't know what to do anymore. finally, i figured that if i held the top lever (#2) back a little the engine would start. i think the lever is too far forward and it floods the engine and will not let it start.
the lever (#2) if left alone tends to move forward and brings the idle way up.
PLEASE HELP. i need to lower the idle. how do i do that? how do i get the lever to stay back?
