1970 Johnson 25hp no spark on top cylinder
bechong
Hey i got a 25 model 25r70c and the top cylinder is getting no spark but bottom is good to go. i was thinking that it might be a bad coil, maybe a bad plug wire or the points and condensor. Just looking for some input to see if what I am thinking right, much apperiacted
bktheking
Re: 1970 Johnson 25hp no spark on top cylinder
Yes could be one of all of those, try cleaning and adjusting the points to .020 with a feeler gauge, inspect coils for cracks and deterioration. Check the end of the wire that is in the dead coil, remove 1/4 and rescrew into the coil, could be bad contact. If you are using plugs to test swap plugs, if you suspect a bad coil swap the coil, bad points-swap the points, bad condensor-swap the condensors- if you have one side that works and one that doesn't you can swap parts between the side that works to aid in troubleshooting as both sides are identical.
bechong
thanks for the responce.
