Jack_toda_Max
Thread starter- Joined
- Mar 21, 2010
- 22
Hi,
I just inherited my great uncle's speedboat. It has a 1962 Evinrude Starflite IV motor with the Selectric Shift. The model code is 50930A. I'm not sure what the A stands for. If I get a repair manual for the 50930 model will it be applicable to my 50930A motor?
I'm in Australia and I'm not really keen on ordering a repair manual from the USA. Does anyone have one that I can download or have emailed to me?
Does anyone know where I can get carb/fuel pump rebuild kits/spare parts? Is there an online store somewhere or is it all through Evinrude dealers?
Thanks for your help,
Jack.
UPDATE.
Well I have a repair manual now and I have replaced the gear case lube, pulled the carburettor apart and cleaned it, inspected the plugs and put some oil down the bores and cleaned the contacts on the ignition.
With the help of dad and my uncle we got the engine started. Under the pressure of the hose with the water attachment there is a bit of a mist coming out of the tell-tale. This is at idle speed.
We gave the boat a short run on the water and there was a small amount of water coming out of the tell-tale but it definitely wasn't like a hose. Maybe just a small dribble. We didn't run it for long and when we got the boat out I checked the plugs and they looked fine. The engine didn't feel or smell hot.
I'm not sure but I think the impeller might be stuffed. I'm ordering a new one from the iboats store right now.
What else will I need to order to replace the impeller?
How much water is normally sprayed out of the tell-tale at idle?/under load?
Does anyone know the operating water temp/cylinder head temp of these engines?
Where would be the best place to connect a temperature sender? (I have read that the number 1 cylinder always gets hot first).
Also when we ran the boat under load I noticed a white smoke. We didn't run the engine long enough to determine whether the smoke was under acceleration or decceleration. It may have just been steam. What are your experiences with these engines?
Finally, when the boat was idling at the boat ramp. There seemed to be a ****load of fuel sitting on the water around the back of the boat. After a minute idling, the whole boat ramp had been covered in a rainbow coloured oil slick. We were running the engine at 20:1 premix ratio and the water choke was working fine. (I turned it to manual off before we ran the boat just to be sure.) The plugs looked perfect after a run, do the old engines always pollute this much?
Oh and do you have to engage neutral each time between forward and reverse or can you just go straight from forward to reverse?
I am ordering a fuel pump kit, needle and seat(not yet needed but it's cheap and might be helpful), impeller and lower gear case seal kit.
I'm not getting a carby kit because they are $51 and it is just gaskets and O-rings anyway.
Is there anything else you guys think I should be getting?
I couldn't find any propellor seals. Does anyone know where I can buy them?
Thanks for all your help. iboats forum rocks!
Jack.
UPDATE.
