This is on a old Shorelandr trailer, 545 5 lug hub. I have replaced the seals, bearings races twice in the last 4 yrs. both times the seal on the inside isn't tight enough. 2 yrs. ago I replace them using a local bearing supplier and we both measured the hub bore as well as the old seal. But when I installed it the seal pressed in too easily so I was skeptical from the start. I even used RTV blue gasket on the edge of the seal. When I removed the hub today to inspect, the seal and inner bearing stayed on the spindle and the hub and the rest came off. Water had intruded and corrosion was forming on the bearing and races.
I am using LM 67948 bearing outer side and LM11949 on the inner. The seal is National 203013 but should be Chicago Rawhide 14977, OD 2.328, ID 1.5 which we cannot find.
My question is should I keep trying to play around with these seals or bite the bullet and replace the whole hub kit, bearings, races, seals and start over?
Thanks.
Joe
Thanks.
Joe
