FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
That is a TN model. It has the water pump impeller on the upper part of the lower unit and I can see the neutral flip lever in the first photo. I would go to vintageoutboard.com, if you need stuff for it, or try Sea-Way Marine, up in Seattle.
just talked to the man that has the motor,its a 1952 tn-28.he said he bought it about 3 years ago and it pulled and had compression.since then its been on the floor of his storage building with all kinds of other stuff piled on top of it.he said he dug it out last week and it wouldnt pull through.ok heres my question,sorry if there stupid,if its in gear would it still pull?or could it just be rusted.i ask about the gear question because he said he didnt no what that lever on the side was for.thanks in advance o sage ones!
It should crank whether in gear or not. 50 bucks is top dollar for an as-found TN. Too much for a stuck one. They are plentiful for $30 at aomci meets.
Spray some PB Blaster in the cylinders and let it sit over night. Keep it tilted up while the oil soaks in around the rings. If it got stuck from sitting in storage, then it should break up easily. Don't worry, you didn't get hurt spending 50 bucks on it. Those are good motors and don't require much to coax them back to life.
