1996 johnson 15 hp ignition
mek07c
Was having problems getting spark on my motor so I replaced ignition coil assembly and motor fired right up. Came back a day later and tried to crank and it did not have spark. I pulled the spark plug inspected it and reinstalled it. The motor fired right up. Tried again another day and motor would not fire so I pulled the plug and wire reinstalled and the motor fired up. What could be going on? Do I need to replace the spark plug wires? I already replaced the plugs and ignition coil. The model number is J15REDG.
bktheking
Re: 1996 johnson 15 hp ignition
Sounds like the coil assembly , wires or plugs have nothing to do with the problem. Sounds more like a wiring harness issue to me or maybe a stop circuit issue, have you tried taking the kill circuit out of the equation?
mek07c
How do you take the kill circuit out of the equation?
bktheking
Follow the wires from the kill switch , there should be 1 wire to ground held down to metal somewhere under the hood.
mek07c
Do I just follow where this wire goes and disconnect it then try to crank the motor?
bktheking
Yes, it's the kill wire, one side goes to ground and the other goes to the ignition module, just disconnect the ground terminal, it will remove the stop circuit all together.
mek07c
Thanks, I will try it out tomorrow and get back with you.
mek07c
I disconnected the ground wire and tried to crank and still not getting spark. What else could be going on?
mikesea
disconnect the whole switch,it could be grounding in the switch to the cowling.Do you have any other kill buttons like the safety lanyard,totally disconnect the kill buttons ,different engines have different set ups.Also check all grounds to your coil pack
