Force 150 power head interchangability
catman31503
I have three engines. Two are short shaft engines that I believe to be 1992 model. One is a long shaft that I believe to be 1993 model. The power head is the problem and I need to swap the long shaft model to the short shaft model. Is there a prblem with the block or crank the would prevent this?
jerryjerry05
Re: Force 150 power head interchangability
Swap away.The only difference is in the lower.Almost every part is interchangable.J
