shwoop_soobie
- Joined
- Mar 11, 2010
- 80
so i searched and searched and i have not been able to find much info...
so i have just had my boat for a couple weeks now and have noticed some issues. there was an awful lot of greasy stuff near the power trim pump....
well come to find out, all of threads on the fittings have been pretty much stripped out, and they are dripping fluid once under pressure...
they can be re-tapped because of the an style fitting....
i have been searching for power trim parts and i have not been able to find another one. its like a small manifold that bolts to the reservoir with an fittings for the hoses to thread into...
my only other idea is to to drill out the entire fitting, tap it with 1/4" pipe thread, and run a male npt to female an adapter.... but if i could just find another little manifold thing with good threads still, it might be easier....
(oh ya, the an fittings on my hydraulic cylinders are leaking too, but nothing unbolts off to replace on them so i am going to just tap it with pipe thread and adapter))
im sure somebody has had this problem before... its easy to cross thread the lines into the aluminum... how do you fix it!?
thanks
thanks
