glassmaster68
Thread starter- Joined
- Feb 17, 2010
- 227
is the lower unit oil supposed to be milky,like water mixed with it?is that normal?
Glassmaster, I would be shocked if any fluid leaked out onto your cardboard. The leaks don't normally occur when the motor is still. Start moving parts thru their gaskets and seals, and the very, very small leaks will allow water in, and MAYBE some oil out.
Even if the issue is the drain and fill screw gaskets. When everything is operating and hot, the air inside the gearcase expands, pushing some air out the tiny openings. When things cool down at the end of the day, it creates a vaccuum inside the gearcase, and it pulls water in thru those same tiny openings. The only way to avoid it is to have seals good enough to withstand the amount of pressure and vaccuum.
I was waiting for the answer, do you need to open the gear case to replace the seal?? Or can you just remove the prop and pop it out??
