big ding and not supported very well alluminium tinny
hayden.burnes1
hi i have a very big ding on the front of the boat and i took out the middle seat of my tinny and it is unstable and you can bend the hull. the ding has been welded over but it is slowing the boat down. what should i do to fill the ding so it cuts through the water better. and what do you sujest to do to strengthen the hull:confused:
Re: big ding and not supported very well alluminium tinny
Ayuh,... Put the seat back in...
Have to See the dent to say how to Fix it...
Triton II
Hi Hayden,
Images of the damage from outside and in will help iboaters to help you. Generally tinnies are pretty easy to fix - aluminium is malleable and weldable so you can beat out the ding and then weld up any tears etc. Then reinforce with welded or rivetted in ribs from the inside. To pretty it up you can use a filler, but it's not imperative. It's probable that your hull is flexing without the seat in place because the seat acts as part of the structure. However, this is guesswork, some pictures of the damage will be a great help.
TII
hayden.burnes1
is there any to strengthen it so i dont need to put the seat back in.
hayden.burnes1
pics of the boat and the ding
bananaboater
Ensign
Looks like the aluminum is really thin. The ding might be hammered out but you will have a hard time getting it perfect. The way it is now no wonder it is slowing you down. The only way I can see to reinforce the hull is to put the seat back in. Good luck.
backlashed
Once you get it pounded back out, you may be able to use some expanding foam under the floor to help support it. Tough call
lakeorbay
I can see why you don't want to put the seat back in. For the leg room. I'm no structural expert, but you need some kind of cross member to replace the bench you removed.
You can get a smooth metal patch to go over the dent on the bottom. The contours would have to be made to match the original shape (not exactly) then rivet it to the boat. I would get a pro for that job.
Do you know exactly how much the dent has slowed you down or are you speculating? For example: It might not be worth the trouble for 1mph.
Good luck.
Triton II
Hi Hayden,
I wouldn't use the boat without the middle seat rivetted back in - it appears from the pictures to be the main structural brace to hold the boat in shape. The ding doesn't look too bad and the weld looks pretty good, but if you really want to de-ding her a little, I suggest a quick trip to your local panel beater. Good luck.
TII
hayden.burnes1
do you think some supports welded on the side like all the new tinnys have would do it without putting the seat back in
Bob_VT
Based on the damage and how far forward it is as compared to that seat....... yes some welded or riveted heavy duty braces will help however...... that dent will continue to spread if not acted upon.
hayden.burnes1
where can you buy alluminium strips that would support my tinny
Bob_VT
What are the road signs made out of?? Normally if a driver hits a roadsign here it will be replaced and here they are mostly good quality aluminum....... scrap yards have aluminum...... or go to a manufacturing place and purchase new.
I like to look for scrap and used stuff first....... makes me feel like I am helping the environment and I can be really cheap at times!! ;)
