$700 to rebuild Carb!!
Recieved a quote from a local marine repair shop and they quoted $700 to rebuild my 1998 Ocean Pro Johnson 150 V6 due to varnish build up. Does that sound right or am I getting the shaft? :eek:
bktheking
Re: $700 to rebuild Carb!!
Carbs, 6 to be exact, $160 just in the carb kits, dissassemble 6 carbs, clean and reassemble with new kits, sync everything up @ $95/hr @ 5 hrs is $475 + tax, seems about right to me.
kenmyfam
Or do it yourself for the cost of the kits.
rjezuit
$160 for the kits, they get at wholesale for probably 1/2 that. 5 hours @ $95 seems a little heavy. Could be getting hosed, or what the market will bear. Probably would have been cheaper 2 months ago when they were looking for work. Rick
bktheking
Agreed but marina's are in it to make money, I bought a $20 OMC tank up in the Muskoka's for $85 2 summers ago. Maybe he can get F_R to do it @ $10 / hour, I remember him mentioning his labour rate in the day. Think $95 an hour is bad, go price out an oil change on a Ferrari. Paying a marina to do lower unit oil and fog the motor for winter is like $200. People pay $200+ dollars to shrink wrap their boats every season!!!Yes it's crazy in terms of the "do it your selfers", I'd never pay anyone $700 to work on my v-4 but if I had the cash and really didn't want to bother doing it I'd pay even more just to avoid buying the tools, manuals , the time and the risk of messing something up if I had a fear of doing it myself.
dieselcat
That price is just crazy:eek:,if i were you I'd do them myself.IMO it is very easy to do,I did mine myself without having any prior experience with carburetors.I also helped a friend with his and neither one of us has had a problem due to the carburetors.get yourself a manual it will help alot.
Hope this helps?
jonesg
I did my V6 last yr, buy the carb kits here on iBoats, I think they were $22 each and it took less than 2 hrs, very simple even the first time round.
Its more difficult removing the carb than the actual "rebuild".
Get the manual.
www.outboardbooks.com
bktheking
Yup bottom line, if you want to save yourself a pile of cash, get a manual, some tools and the kits.
1946Zephyr
Yea, I was just reading shop rates at my local marina today too. $96 an hour. Holy gads! Things have really gotten expensive:eek:
bktheking
So I guess my $95 assumption wasn't far off the going rate. That's why when people get an estimate on what it costs to do any amount of work they fall off their chair. I was talking Ferrari, a buddy of my dads has a Testerossa, in order to get the oil changed Ferrari of Montreal brings a flatbed to his house, bring it to Montreal, do the change and then bring the car back with a bill for $2000. It's one of those "you gotta pay to play" type things and the marina's know it.
rjezuit
If you can afford a Testarossa, you can afford the oil change. Rick
22E6441
Like others have said, do it yourself. The tools needed are actually minimal, and the kits come with everything you need other than some carb cleaner. I did my carbs last year and couldn't believe how easy it was. I did the grunt work, but then brought it to the shop for a link and sync because they have the test tanks and weighted test props.
I got the best of both worlds the way I did it...saved a bunch of money, and had the fine tuning stuff done by a pro.
Mr5Keepers
OUCH.... I charge $180 to clean and set OMC V-6 carbs.. any parts needed are extra... Not hard.. doesn't take that long.. you will need some professional carb cleaner ..usually comes in 5 gal. with a basket.. DO NOT put ANY GASKETS/O-RINGS/PLASTIC/etc..etc.. in this cleaner.. they will be usless afterwards if you do!!!!
Use ONLY factory (OEM) parts!!!!!!!!!
about a 3-4 hr job...
.. YOU are getting VARNISHED!
izoomie
Pat; what did they charge you for the Link and Sync?
izoomie
22E6441; I just noticed you're in Hamilton. I live near woodstock and work in guelph.
Who did your L&S?
Nick
22E6441
It wasn't much.....I think it was only an hour labour, and they did a couple other small things too.
I had it done at Dundas Marine on Hwy 5. I've been in there a couple times and like them a lot.
