Well here goes ! I attempted to replace the drain tubes in this old girl. First one went well, good wood and solid. You know the rest of the story.
I spent 2 days taking the transom out with a surgically precise chain saw. Got the stringers cut out and the inside with a Harbor Freight vibrating cutter tool. Greatest 39. bucks I ever spent.
I had to cut the inside upper corners off the inside of the transom and plan on replacing with wood all the way to the floor then tie the stringers into that. I will wrap all the wood with glass then glass the stringer to the inside. Once that is done I plan on using Seacast for the transom.
If you can drop me any hints it would be greatly appreciated.
