1973 Marlin Restore
ogrealan
Hello All,
I have decided to take on the task of restoring an old boat that has been sitting for a long time. Why you ask well to be honest I was inspired by Archbuilder and the phenomenal job he is doing restoring his "Miss Morgan". I recieved the boat about 6 months ago and should have been working on it much sooner however finances didn't allow it at the time. I now have some time and a tight pocket book to start. (Flap disks and grinding is pretty cheap). I am having the darndest time uploading the photos that I took to photobucket so pictures will be coming soon. Mostly just pictures of the transom removed and grinding of the floor and bow section. A little on the back ground of the boat is that I got the boat, trailer, and motor (Eve 115) in November. The entire transom was mush and didn't take much to remove, but the transom glass is in some rough shape due to the motor punching through (fun fun). the floor was almost all gone when I got it except for a small section of stringer and a 2ft triangle of wood under the bow. I don't know if the motor runs but I have the controls and what looks to be all the hardware. The steering if shot from years of sitting outside so that will need to be replaced.
As for the idea that I have for the boat is, New pour transom (Nida-Core), New floor (3/4 Ply), urethane pour foam, single stringer (came that way from the manf), bilge pump, battery, new gauges, and I'm going to attempt the roll and tip method I have seen on here to re-paint. Another beni I have is it does have the original back to back seats and stern access (all need to be recovered) I might even give that a shot as well.
It will be a long process but the goal is to have it out on the water this year. Any suggestions and comments will be much appreciated and I will try to post each weekend after work is completed with Pictures.
Bow
Under Bow
Thanks
Alan.
ezmobee
Re: 1973 Marlin Restore
Welcome! Got any shots of the overall boat? Looks like it's probably a pretty sharp one. If you're going to be documenting your restore, I highly recommend setting up a photobucket.com account and hosting your pictures there. Much easier than attaching them to iboats and there aren't the strict file size limitations to deal with.
In my opinion (for what that's worth :p) the pourable transoms are great for when you've got an otherwise nice boat you don't want to have to tear apart to replace the transom. For complete rebuilds like yours, I'd save my money and just go the plywood route. Properly sealed and glassed, it will still outlive you.
ogrealan
Ezmosbee,
I have a photobucket account but having problems uploading photos to it at this time. I will try it again when I get home since I think there is some proxy setting not letting me upload from work. I do have one picture of the full side but I'll take some more this weekend when I get back going on it.
Thanks
Alan.
ogrealan
So I have continued to work on the boat over the course of the week and hope to have pictures of the seat I have finished (home sewing). It's not the best thing I have ever seen but I did the whole back to back plus seats for $35 in vinyl. I should be able to post some pictures tonight. Haven't done much with the transom at this point I have to save up a little for the material still.
I do have a question for the masses out there. I do have a Evinrude 115 I believe it's a 73 and the remote control box is in pieces. I will try to take a picture for reference but it looks like someone hit it with a hammer. It's a single handle with 3 buttons on the top Forward, Neutral, Reverse and the ignition on the front. Being that I won't really be able to put this back together can I utilize a standard control maybe one from Tereflex and wire in an ignition switch? I do have the harness cable from the Evinrude. Don't know what wires go to what but I believe I have seen some diagrams around on the site for it.
Thanks
ogrealan
Ok I promised some pictures of the boat as I went along. I did get one seat completed today. There are a few wrinkles but for 35 dollars I can't complain.
Passenger Side Seat
Full Side View
Test Fit
All Done. About 3hrs of sewing and cutting. Not perfect but it will get the job done. Not bad for not having the orignial vinyl. Prior owner couldn't find it.
ogrealan
Just waiting on the 1708 and the pour foam to finish up the Transom. Still filling in the holes from where the Outboard punched through the transom. I have two more spots to lay up and then sand and feather. Should have them done this next week. Due to holidays shipping isn't going to be here until Monday. Here are a few pics of the boat from the drivers side. Gives a view of the lines. Sorry for how dark they are but I didn't get done till it was already dark.
Side View
Bow View
From Bow to Stern:
Lots of dust to clean up so Sunday will be a clean up day from all the grinding.
ogrealan
Ok one more picture. I thought you all would get a kick out of this. Under the small triangle of 3/4 ply in the bow of the boat I found the only piece of stringer that was left. LOL
Maybe there is enough left to get a template for the curve into the bow but I doubt it. Going to have to rig some sort of jig.
Hope everyone has a wonderful weekend and holiday.
ogrealan
So I am continuing to work through the little things on the boat these days. Funding got pretty tight there for a little while so if it required parts it had to be put on the back burner. I have finished the inner skin for the transom and will be using a piece of pink hard foam with a layer of plastic to laminate up the inner skin. I should have that completed this weekend and hopefully put in the single stringer. I have decided on going with the Nida Core pour transom because I got a really good deal and it would be about the same as the 1 5/8 ply. I'll take some pictures this weekend to keep in posting and following Arch's amazing miss morgan. I'm not nearly as qualified as Arch but I do plan on taking many of his trials and using them to my advantage when I can.
I am wondering how the seats (back to back) frames should be secured to the hull. Should I glass in some Tabs and then screw stainless into the tabs?
Thanks
Alan.
Og,
Looks like you are moving right along. The seats look great. Sounds like your idea will work but it is kind of hard to answer your question because the pictures don't show a complete before and how the seats are actually going to be oriented inside the boat. Also if you only have one stringer you could use the Nida core for that also.
As far as the Evinrude 115, the exact model number will be on the engine bracket. You can look that up and see what it is you have. If you plan on doing a lot of work to the engine I highly recommend getting the factory manuals. They are a little pricy but well worth it and will answer all your questions regarding the remote and wiring diagrams.
Have fun and keep plugging away.
