How to replace water pump impeller on selectric shift?
merc20076
I received my new water pump impeller for my 1966 LarkVIII 40 HP.:)
I think because it's a selectric shift there are a few wires to disconnect when removing the lower unit. But I don't know which ones? Also what are the bolts and screws I got to remove on the lower unit? It is a bit confusing and I don't want to damage anything on this great outboard.
Thank You for helping me
F_R
Re: How to replace water pump impeller on selectric shift?
See the big outer cover over the rear half of the mid-section? That has to be removed. If it is long shaft, there are covers over the 5" extension too.
OK, with the covers off, you will see the wires. Disconnect them at the powerhead. Now remove the diamond shaped cover plate about half way down. Behind that, you will find another cover plate that the wires are coming out of. First feed the wires through the hole created when you removed the first plate. Then remove the screws from the second plate and pull it off of the wires.
NOW, you are ready to remove the gearcase. First tie a string or something to the wires. You will need that to pull the wires back up through when you put it together. Then remove the big bolt at the rear, and the six smaller ones above the cavitation plate. Then a gentle twist and pull and the gearcase will come down and away. Carefull--don't pull your string all the way out, untie it.
You will now have the water pump right in front of you.
When you put it back together, make sure you have new o-rings on the top end of the drive shaft and on top of the water pump housing. Apply a smear of grease to the drive shaft splines and water tube grommets. Get somebody to help you pull the string up while you install the gearcase. Make sure both water tubes enter the grommets in the pump.
Slop some oil on the ribs of the shift wires before installing the cover plates.
merc20076
Thanks F_R for the directions!
It doesn't look that simple. I have to order new o-rings and I wonder what to order, there are many on I boat store. I just ordered the impeller from Iboats.
I have the 20'' model so I think it's the short shaft.
I still have a good month before the boating/fishing season to do the job.
merc20076
UP!
I don't have the O-rings part number for my ouboard. There are many on Iboat store. There is not much I can do for now without the new o-rings. I just have the new impeller.
