Moody Blue
- Joined
- May 24, 2004
- 3,136
Re: boat leans to the left at a steep angle
Its not just a factor of how much weight is up front, but also what angle the motor pushes the boat thru the water. The fact you get on plane quickly indicates that the motor is trimmed full down. That is good to get on plain but BAD for running.
Not to worry just yet. More than likely just a setup problem. The more detailed info you can provide the better we can all try to help. Answer as many of these questions as you can ......
Do you have power trim or manual?
Is the steering stiff while stopped also, or just while under way?
Where is the anti-ventilation plate of the motor relative to the bottom of the boat?
Is there a trim anode installed on the bottom edge of the anti-ventilation plate behind the prop? If so, what direction is it oriented in?
While underway, is there alot of water spray from the bow?
The only thing I had in the front of the boat is a 12 pd anchor, and a small battery + the trolling motor. The weight on the boat says 940 pds. Dry. The boat goes to plain very quickly.
I'm a bit flustered at the moment thinking that I got ripped off. Guess I should have waited for open water, and test drove the boat first.
