fixb52s
Thread starter- Joined
- May 14, 2004
- 463
I am currently have 1985 3.0L Mercruiser engine that has a trashed block. It appears to have been overheated and cracked a cylinder and the deck.
I have searched for a replacement block and found one from a 1983 Sea Ray. Even though it was marked 3.0L and the block casting number checked out, it turned out to be a 2.5L. The block though is in perfect shape. It has the same casting number as the 3.0L (2770087) but has a 3.877" bore instead of the 3.99" required for the 3.0L pistons. I want to reuse my 3.0L crank, rods and camshaft along with some new 3.0L pistons. Can this 2.5 engine block be safely bored to the 3.99, or should I just put it back together as a 2.5L? It appears that GM used the same engine blocks for the two, but my local machinist is not sure it can be overbored .110. Any ideas?
