carb rebuild kit and motor info for 1990 force 150?
swey00
I just recently purchased a 1990 arriva w/force 150. I've looked where a couple threads said to look for the serial # on the motor to find the model which I cannot find. I did get the numbers off of the carbs and some off of the motor. Everywhere I look it is asking for a carb part # that starts with FK10xxx, but the only thing on the carbs is:
Top carb: TC-103A-912 other side of carb is 686061
Middle carb: TC-104A-912 other side of carb base is 693061
Bottom carb: TC-105A-846 other side of carb base is 694061
On the left side of the motor on the big flat part there are these #'s:
D3N9B
694866
On the rear of motor by the spark plugs is:
694518
On area above carbs:
440167
Sorry for the long write-up, but from reading here, none of these numbers are the engine model or serial #. I was just wondering if any of you could tell me what type of carbs I have(the only carb kit I can find is for Tillotson not Walbro) and any info on my motor would be helpful. I am going to go check out the engine area again tomorrow to see if I can find the serial or model # again.
swey00
Re: carb rebuild kit and motor info for 1990 force 150?
I went to take another look at the boat and could not find the serial or model #. I did take some pics of the carbs though, so maybe someone might be able to help identify them. Here they are:
From what I have read on here, the most likely place for the serial is on the mount that mounts the motor to the boat on the left side. There was a sticker there, but it has worn off. Here is a pic of it:
Any other ideas on where the serial # is? Any help is appreciated, thanks.
swey00
Anyone?? I guess if I don't hear anything, I will just order the carb kit that shows is for the Tillotson carbs...
thompy
that is what they look like to me
jak160
I have a 1992 Force, that has the same Tollotsin carbs you have on yours. My mechanic told me don't waste your money on the carb rebuilt kit if the reeds weren't damaged and bowls looked clean. And mine were. I only changed out the needle and the gaskets on all three and cleaned up the carb with with spray carb cleaner to clean up some grime that was on them. Hopefully this can be of some help!!!
swey00
well the kits are only like $12 all the gaskets are like $6-8, so i might as well get the rebuild kit...i just wasn't sure on which ones they are. They are flooding pretty bad too. I am pretty sure this is the reason it is not starting, so hopefully it will fix it. Thanks for all the help.
