I need a mercury oil warning module 41470A27 old # 41470A11
Jonezin
Anybody have one they would like to sale. They are hard to find and when I do they want a million dollars for it.
Jonezin
Re: I need a mercury warning module 41470A27
whoa 201.31 + 13.00 for shipping
Thanks, I'm sure somebody has a good used one
Re: I need a mercury oil warning module 41470A27
what's it off of i have one for a 4 cyl and a 6 cyl both the early 90's vintage.
Jonezin
I have a 88 merc 135hp v6 #B278681
Give me the model # and I see if it fits
Thanks
sbklf
Bend over. I confirmed that no one could perfect the circuit so there is not an aftermarket part in Sierra or CDI. That is the one I need as well.
Jonezin
I'm sure somebody has a good used one, lets keep looking if I come a cross 2 I'll send you a note.
sschefer
Re: I need a mercury oil warning module 41470A27 old # 41470A11
Try ebay..
j_martin
Tell us what it's going on. Sometimes different ones will work with a splice or 2. Ask me how I know.
sschefer
I think I have a couple laying around somewhere. I'll look tomorrow. I think mine are newer. Well early to late 90's anyway..
Jonezin
Thanks let me know
j_martin
For an 88 135, any module from there on up through the EFI series of engines should work. There are several different terminal arrangements, but that's what they make solder and heat shrink for. The EFI versions have an extra wire that goes to the water separator. It's literally T'd into the oil cap sensor wire, so you can just cut it off.
They all have one wire that goes to the ignition for a signal, a supply and signal wire for the motion sensor, a pair of wires for the oil cap, a power supply, a ground, and an output wire. The color coding could vary, but not much.
In other words, any oil alert module on any v6 up to and including an EFI will work if you are handy with tools.
hope it helps
John
sschefer
Thanks let me know
Ended up on the wrong end of a power washer all day today. I'll check tomorrow when I'm cleaning up the garage. God I hate spring cleaning! COME ON SUMMER!!!!!
Jonezin
OK got it john
would one from a 40hp work as well.
I love spring cleaning that's when I find all of my tools and most of the stuff I've been looking for.
nosgsxr
Not to high jack this forum. But i also need one but my part # is 41470a17. Any help would be great ..I think it a 150 or 175 1993
saumon
No, depending of the model/year, a 40 will either be a 3 or a 4 cylinders, not a V6 like j_martin told you.
Jonezin
Thanks for the info Buddy
