2stroke1971
Thread starter- Joined
- Nov 8, 2009
- 210
I got my aq125 started, its in a 1984 bayliner. Ive been thru this motor quite a bit since I bought it, and finally got it fired.
Ive got a plastic 50 gallon drum that I cut down and IVe got the outdrive in that. Its running a bit rough, Ive got to tune it. It sounds like an exhaust leak, a bit like a lawn mower if you know what I mean. I put new exhaust gaskets on it so Im not sure about that, but I will get to that.
I left it idling for maybe 5 minutes at one point, revving it here and there. It seemed to bog a bit but again i will get that ironed out. The temp needle seemed ok...
So where the copper piping comes out of the bottom of the exhaust manifold, theres 6 inches of copper, then I have a big clear hose there that runs for about 10 inches, then its copper back into the strainer neck of the heat exchanger. The hose felt pretty warm, Id almost say hot. Is that normal? (again this is between the bottom of the exhaust manifold and the strainer neck.)
I though that fresh water comes flying through that pipe constantly...so wouldnt it stay pretty cold? My barrel of water was nice and cold at the end.
Also, the exhaust manifold was hot. I thought these stayed fairly cool on marine engines. Most worrisome is that there was only a trickle coming out of the exhaust port. The exhaust port was just out of the water, so normally, water should be gushing out of there along with the exhaust right? I did not observe bubbles in my clear hose, but Im not sure the water was really moving thru. Again, Id expect that to stay cool.
So, Im thinking seawater pump issue, but Ive been thru that. I put a new front seal on it, and a new cross piece (coupler). How long should the seawater system take to prime if its bone dry?
One more thing..when you open the cap on the strainer neck of the heat exchanger, what part of the system are you looking into? Why is there even a cap there? I thought coolant went there, and I actually poured some in, and it showed up immediately down there in my clear hose headed to the exhaust manifold. I cant fathom why there would be a cap there or why what I poured down that neck made it into the seawater system.
(Im not talking about the radiator cap type cap, I know thats for the intake side system. )
I dont want to try and tune it in or even run it anymore until I figure this out.
