Optimax 225 power trim problem
Jim Peterson
My 2003 225 mercury optimax power trim will not work. The solenoids click and there is power to the trim motor leads. The engine has been in storage in my garage for the winter. The battery is fully charged. I realize the electric motor and or pump may need replacement, however is there anything I can try first?
wtwe2step
Re: Optimax 225 power trim problem
Sounds like not enough juice. Insure that the battery is good. You can try jumping it with the car to test. Insure the connecters to the solenoids are clean.
Jim Peterson
The starter motor turns the main engine over and the hydraulic jack plate works fine. The battery is almost new and reads 12.5 volts on my meter. It is possible the amperage going to the trim pump motor is not enough. if so where would it be restricted?
wtwe2step
It's possible that the solenoids are bad but for both to go at the same time would be strange. Bad connections would cause a loss in amps. Check the amps at the solenoids.
