well, put the evinrude in the dump tank today after winter storage, got it to idle down once warm but no water spraying from exhaust port (year prior to water overflow indicator(pee hole)) but when i reved the motor water would pour out of the port. Then I did the hand test by resting my hand on the top of the block to see if it was too hot, and it felt hot. So I'm assuming i have a weak water pump:
Basic question; how difficult is it for a guy with basic knowledge to put a new water pump kit in? I've done a carb kit, recoil spring and fuel pump kit last year, and guessing the h20 is alittle more complex? I plan on purchasing a repair manual for my motor, so i dont need specifics just ideas on what i should expect and what, if anything else i should purchase while i take it apart?
any suggestions on repair manuals?
thanks
thanks
