Boat 1997 Wellcraft 190CCF
Weight around 2000lbs
Motor 1997 Johnson 115 spl, set at one bolt hole up
Prop is a Power Tech rxb4r15pom140 that I bought new a year ago has some where from sand bars. The diam is 13.25" pitch is 15 and is SS four blade.
With 1/2 tank of gas, 2 people, at wot if I continue to trimed up the prop blows out at 5000rpm. If I stop trimming before the prop blows out I don't get any more rpms or mph, 34 with gps.
With the boat loaded 4/4 on gas, coolers, ice. wot is 4800rpm at 31mph.
I normally run the motor from 3800rpm to 4200rpm at about 24 to 26 mph.
My concern is am I harming this motor?
prop link http://www.ptprop.com/component/pag...acturer_id,0/option,com_virtuemart/Itemid,46/
Or will setting the motor down to the transom help?
Or should I have this prop repitched to a 14" or 13" to bring the rpms up to 5500?
