1988 Johnson GT150hp VRO swap
Boyd D
The VRO is bad. I want to swap it for a fuel pump and just pre-mix the fuel, but I cant find this in any book. I need help ! I'm on vacation next week. HELP
beavers82
Re: 1988 Johnson GT150hp VRO swap
I may be wrong, but if your fuel pump is still working you can just bypass the oil side. This is what I did, but my vro was still working. Lots of info on how to do it if you search. It walked me right thru everything. It is simple.
ezwitter
beavers is right if the fuel side is working just plug off oil side drain carbs premix fuel. pump it up to carbs fire it up go fishing. the change over to install the pump is on johnson engine thread just serch for it. good luck
