Hitch Drop question
kyle f
So, my last truck was lifted a bit, and I had to use a 5" hitch drop for my ball. Well said truck is gone, and with my "new to me" SUV, it sits a lot lower.
With some decent weather this weekend, I decided it would be a good time to start to get things ready for boating season. Checked the trailer lights, wheel bearing grease, tire pressure, and since it has been sitting in one spot all winter, I wanted to move it about a foot or so to help fight flat spots, if any, on the tires. This works out great as I need to set the hitch up on the Escalade and check that the plug wiring works.
Obviously, the 5"drop wont work. So, I got my other hitch out that had a 1 or 2 inch drop, and installed it. Well, after putting the boat onto the truck, it was barely high enough to get the trailer jack wheel off the ground. Took a step back and noticed the boat and trailer were at an angle toward the truck. Thought to self, "This won't do and I am sure its going to make launching and retrieving a bit more difficult".
So, I had seen it before, but not sure about the safety of it. I unhooked everything, took the ball off the hitch, flipped the hitch over, and re-installed the ball. Now I have about a 1 or 2" lift above the receiver.
So, question here is... is this safe or even practicle to install it this way. This gave my trailer just the slightest bit of nose rise, but I can't honestly say that I have seen too many rigs set up like this.
Proselect
Re: Hitch Drop question
Most ball mounts that are set up with a 1 or 2 inch drop can also be used for a rise. That part I am sure you are safe on as long as you aren't talking a super amount of tongue weight. I am not sure on your trailer angle. I have heard that if anything you want the tongue slightly lower than the back of the trailer for the best handling and breaking. Level is good, but if you are a hair above level I would run it down the road and see how it reacts on the highway. Make sure it pulls straight without any sway. This is my 2 cents and maybe somebody knows something I don't about it.
Ayuh,... That's how it's done,..
The draw-bar don't care which way is up, or down...
Having the trailer level, or slightly High is better than low,..
As your tow unit will more likely be loaded heavier, hence lower when goin' boatin'...
kyle f
That was the other thing that concerned me, other than a full tank of gas, the boat is completely empty. Figure the nose will get just a bit heavier once I put 7 Lifejackets, 2 tubes, surfboard, 2 wakeboards, slalom ski, 1 pair double skis, fat sac, fat sac pump, 2 wet suits, tower speakers, wakeboard rope, 2 tube ropes, surf rope, boat documents, cooler full of ice, 12 pack of beverages, bumpers, ropes to dock with, multiple towls...and whatever else we take out on a trip.
rexmitchell
I see people run it like you do all the time. Should have no problem as far as strengh goes.
Utahboatnut
Thats how I have run mine for ten years and numerous types of trailers and have never had any issues, it was a disaster when it was flipped I had the same issues with my trailer jacks not going down etc. after the flip it has been just perfect and no deflection in the hitch(I checked it a lot). Good luck..
redone4x4
our boat loads the trailer down ALOT after we fuel up. So much that we haul everything possible in the truck until we get to the launch ramp. Then switch it all over. Too bad boat trailers dont have air ride like the big rigs :D
H20Rat
just keep in mind the higher the ball mount, the less tongue weight you get. (assuming no other variables change)
anyway, higher mounts also usually make for easier loading and unloading, especially on really shallow angle ramps.
woosterken
i have posted this before,but now that its spring, this came with my hitch
woosterken
Black Snow Slide
Check your tung weight. With a lifted truck I am thinking it might have a heavier spring load then the new Caddy and tung weight wasnt much of an issue. If tung weight is good then set it up so the trailer is level and the Caddy is as well. Have a great season.
Philster
If you're level at the tongue/trailer with a 2" rise, it's equal in difficulty to a guy with a similar amount of weight and a 2" drop.
Just spread out any loads that you can. If she is staying level, and the boat sits on the trailer properly, and you have the proper rated tow vehicle for the total load you are hauling (people, gear, fluids. etc), you are good.
