1985 35HP Mercury need help finding a part
Bull54
I have looked every where I know to look but have been unable to find the part, hell I don't even know what it is called. It is the piece that holds the shift cable in place on the motor. That piece has a small hole piece that screws down onto the motor.
Also when trying to get the motor into neutral to replace the cables, the prop will turn but you can hear a clicking noise. I sprayed everything with WD40 and was able to get a spot in the middle that the prop will turn and no clicking. However, the prop does not free spin it is kind of tight but will turn by hand. It turns to the right but will not turn to the left no matter how hard you try hope that is good :D
I have a Seloc manual which is worthless for this and I have been unable to find any diagrams for this motor. If someone knows where I can find one online let me know. The serial number for this motor is A120274.
I have attached photos for you. Please anyone that can help me quickly would be appreciated. Thanks
achris
More fish than mountain goat
Re: 1985 35HP Mercury need help finding a part
It's called 'Latch, Shift actuating slide (shift cable)', it's part number is -56193, and it's NLA from Merc... Precision Marine in California have one... Ph (800) 665-5115.
Chris......
Bull54
Thanks
Bull54
Ok got the part order, I appreciate that info. Now just need help with the rest of the post then I will be set.:D
Bull54
I solved the free spinning prob.:D Thanks guys.
