The Grayt 1
Thread starter- Joined
- Mar 30, 2010
- 51
We just bought a very clean 93 Seaswirl ski boat. the boat was in very good shape and has great wood and a clean hull. We are totally new to the OMC cobra outdrives and noticed when we test drove it Friday it made a slight grind into reverse at cold start but then went away. The throttle seemed to be a slight bit stiff. I know these need to be adjusted properly or you can ruin gears. Once the boat was warm it shifted great into forward, reverse or idle. Just a little stiff. We really like the boat and want to keep it, but want to make sure the outdrive is fine. How do we adjust it properly? Is 93 the one with the good gears?
Finally, we are also new to boating. What services should we do to it. The outdrive oil and engine oil were just changed as well. The boat ran great for the first time out this year. We had it out there for 45 minutes. Also we paid $2750 fir the boat and trailer. It came with everything as well. Did we get a good deal? Thanks in advance!
