Trying to get motor ready for the season. It will not fire on bottom plug unless rev up 1/4 past start. when rev up i can take the top plug off and it will still run but when i come back down to start or lower run for a few seconds and die. when idle it will run fine then miss for a while and go back and forth. when in trash can of water it will go to wot in gear sometimes but sometimes seems to bog down smokes really bad. Don't know if it could be coils points or maybe compression. Looked through flywheel coils look fine but i can see a green wire and red wire looks like coating is coming off. If anyone got any ideas. I would sure appreciate it. thanks also new plugs and rebuilt carb.
