Need a Carb linkage diagram for 87' 90HP
bang4dabuck
Rebuilt carbs last fall which was my first time. Unfortunately I didn't take photos like I saw suggested else where. I have an early 80's model 70HP Merc around, should be pretty similar right ? I see parts breakdown but it's an exploded view and rather vague as to how it comes together. A couple photos of the connection at both carbs would be great if anybodys' got them.
thanks
Re: Need a Carb linkage diagram for 87' 90HP
there is only one link bar, that had to be removed to get the carbs apart. it just snaps in the carb throttle cams.
bob johnson
thanks
I can take some picturesof a 1987 88 special i have in the yard.
will that work for you?
port or starboard???
the air deflector is still on!!
bob
bang4dabuck
From starboard side. It would be great to have 2 good photos of the linkage connection at the top and bottom carb.
thanks alot
bob johnson
since I am selling this motor( bad cylinder) I actually have a few pictures already and you got lucky , one is of the carbs from the starboard side..
if you need me to send it bigger, i wont size it for the forum next time
bob
bang4dabuck
That ought to do it
That ought to do it
Appreciate the effort.
thanks again
