Driveshaft removal on a 9.8 "110" Mercury, please help!
zz_denis
I need to remove the driveshaft out of the gearcase on a 1970's 9.8 hp Mercury "110"
I removed the impeller housing, and can see the drivesaft bearing. I dont see any screws/bolts that could be removed. Is there a trick to taking the thing out?
Thanks!
Droll
Re: Driveshaft removal on a 9.8 "110" Mercury, please help!
No tricks... just more work..
You need to :
  • Remove bearing carrier nut
  • Pull out propeller shaft ( with reverse gear )
  • Loosen the pinion nut ( on the end of the driveshaft, INSIDE LU )
  • Remove pinion gear
  • Pull out driveshaft.
Arne Kjetil
Laddies
Banned
Remove the propshaft carrier, reverse gear, then the pinion retaining bolt and pull the driveshaft out
zz_denis
Thanks guys! Got it!
