Used my Johnson over the weekend, now I have the drip.
fortyfreak9
I have an 89' Johnson 110. Oil injected. I started it for the first time since the fall. I ran good but when I shut it off alot of black oil and oil water mix was coming from the exhaust area. I let if sit for the night and had a nice pool of oil on the ground. Cleaned that up, checked again the next day and had the samething. It is not lower unit oil, I had just changed that and this oil is way to dark to be that. Is it common for that much oil to be coming out after running it?
Chinewalker
Re: Used my Johnson over the weekend, now I have the drip.
Perfectly normal. It's unburned fuel/oil mix - the downside of a 2-stroke...
22E6441
I always flush my motor after I use it, and leave the hose on for a few minutes after I shut the motor off. Cleans all the goo out and then you get no drips.
reelnative
they make penisillin for that problem, hahaha jk for 2 stroke motors that normal, a good thing to do is just put a rag down under it
