How fast will my new boat go
ezmobee
Re: How fast will my new boat go
There's much more than $100 worth of parts there if nothing else. I had a similar vintage Johnson 85 and it was a great motor. Sold it in excellent running condition the end of last season.
marlboro180
it is worth every penny. Nice lady to let you get it running, then decide.:)Pay her before I let my buds in Sebasco know it is out there!
its a longshaft, i think its looks kinda cool, the outboard is just about 5 feet tall, its rediculous
Ayuh,... cause it Is ridiculous...
Is going to run like crap,+ handle even Worse...
You've be lucky to make 30mph without dumping it...
Running a long shaft motor on a short transom boat is Begging for Trouble.....
csdwarf
I dont know for sure the boat calls for a short shaft, the cavitation plate lines up just about with the bottom of the transom
that tells me that the boat needs a longshaft engine.
right now im going to empty the water out of the barrel and get some lower end pics
now im curious
EDIT---Siphoning as we speek :p
ezmobee
Actually it sounds like you're good. The cav plate should be even to about an inch or so above the keel.
csdwarf
that would make sense because i was thinking it was a little under the transom, still ganna get pictures to make sure
EDIT- Well now it wont let me upload pictures so i guess thats off
How warm should the water be before i go try it out?
marlboro180
Long as there is no ice in my book....Just stay in the bay, wear a pfd( but you knew that..) and bring some tools with you .
What, the fisherman are afraid of cold water out there now??:D:p
csdwarf
Yeah good point, maybe i will try it out this weekend, or tomorow after school :p
lol, i love the water, but its really cold right now and I dont have any experiance with the boat,so anything could happen
heathk2003
I will guess 42 mph with a good prop ... keep us posted!!!
csdwarf
alright ive read up on cold water survival a bit and looked up some facts
the water temperature on the lake today was 46 degrees, thats like over an hour of survival so im fine trying the boat out this weekend
ill just stay in the cove.
ill be able to tell you guys :p
anyone got anything else to say, every seen a boat like this
what kind of boat is it?? lol i know its a seebreeze but what is it lol
UncleBoatMan
I had a boat like that and it regularly went 65 or 70 ... to and from the lake ... slower if it was in the water,
marlboro180
Its a runabout, and with that 70 on there and if it running properly it will make you grin like this-->>>:D
csdwarf
Tryed the boat out, ran good but when i tryed to open it up it would just die out, took him home to find all of the highspeed jets were totaly plugs
i got it up to 32mph(gps) with no highspeed jets, not im really curious how fast this thing will go
stylesabu
how did it handle? my 16' deep "v" hull with 75hp suzuki 2 stroke will hit 38 mph with 2 people 12 gallons of gas, and a cooler. I would think 43 or so could be reached. the guys in the prop section can help you dial it in, I recommend you stop by get schooled in proper prop and engine hieght on transome, it made a differance for me and my boat
csdwarf
me (155lbs) my dad(210ish) 6 gallons of gas a deep cycle battery and 2 big comfy heavy chairs
had it doing 43 it was still climbing but i dont like to run stuff real hard, would do 45 i bet
handles great, when i drove it alone tho the boat is so light that it turned really sharp to the right and when i wasnt on plane and getting onto plane was a little weird because it was tilted from me being on the right
and with the prop, i think i could put more pitch and maybe get it to do 50 flying solo, it got there really quick and punched hard when i went wot from anyspeed.
i dont have a tach so tuning in a good prop would be hard wouldnt it?
can you tell if this boat is a deep v hull?
