jetski39590
Thread starter- Joined
- Mar 31, 2010
- 5
I have a 73 20hp johnson . I have a problem with the motor not running without full or partial choke. Can't idle so to engage drive. I have renewed plugs points condensors full carb service kit, soaked and blown out etc the carb is clean for sure.New fuel pump service kit.I have also bypassed the pump with a bucket of fuel on a step ladder to rule out the pump and tank non returns. I can start the motor no problem and let it warm up for a few minutes but as soon as I try to take off the choke it will die. As per instruction from other post If I spray fuel oil mix down the carb throat it picks and revs great for a few seconds and dies again, another squirt off it goes again. Its sounds like a blocked high speed jet but this is fine could it be reed valves? I have done all I can any suggestions. Oh I've checked the carb bowl after it dies and it has plenty of fuel in there. One last word I should run fine without a carb silencer shouldnt it as I dont have one fitted
Simon UK
Simon UK
