I have a 1983 evinrude 200 hp. It idles fine however when giving it full throttle it starts running rough above 2000 RPM and will not get on a Plane. Sounds like its missing. I have replaced all the spark plugs. I checked all of the coils and Spark plug wires and did not see any cracks in the coils or nicks in the plug wires. I checked all of the power pack connections and everything looks ok. I checked the blocking diode in both power packs and everything checked out good. I ohmed out the charge coil and it reads 560 ohms for both of them which is ok. When I ohmed out the Starboard sensor coil I get 33 ohms between A and D instead of 18 ohms. The Port Sensor coil reads 18 ohms between A and D. The rest of the sensor coil readings appear normal. The spec is +- 5 ohms so it is out of spec. Could this be causing my problem. This is a very expensive part and hate to throw $320.00 at troubleshooting this problem and find out its something else.
Thanks
Thanks
