IronOutlaw
- Joined
- Jun 27, 2009
- 44
Ok the motors been sitting for three years and was parked with no problems says the prior owner. I got it fired up and noticed no water coming from pee hole. I cleaned out the tube and even disconnected the rubber hose from the engine and looked through it only to find it was perfectly clean. I then pulled the lower unit and took apart the water pump and the impeller looks brand new. I brought it to the local shop and showed it to them and they said it was the right impeller and gaskets.
I'm stumped. I guess tomorrow I'm going to run some significant water pressure through the engine to see if I can blow anything through it. Any suggestions aPpreciated.
