fixing Transom
stoksey25
Hi there I am in the process of taking the top off and redoing the transom but I need to know how is the best way of fixing the new ply in. I was thinking of resin and clamping then glassing on the inside does this sound right of is there a better way of going about it
Many thanks Neil
oops!
Re: fixing Transom
hi stosky...
there are several methods of doing it....just search transom....and youll have your pics of how to do it....the com0leated projects forum is full of great examples.
what you want to do....is after the transom is built....coat the tansom with resin and glass....install transom....and clamp it to the hull...this can be clamped in the standard ways....or you can drill holes thru the transom and use the holes to thru bolt it....(coat the bolts with wax so you can remove them later....the towing hook holes are a great place for this)
make sure that when the transom is installed there is no voids between the hull and the new transom....
after its in and cured....just fill the edges with peanut butter and glass the whole shabang to the hull !
cheers
oops
jonesg
Re: fixing Transom
Dry fit it first, drill all the clamping thru-bolt holes so you're ready to draw it tight asap. You'll only get 10 minutes to get it in there and clamped with poly resin.
The trick is to rehearse it before doing it.
And use Glass Mat between glass hull and transom wood, it will fill voids better than cloth.
If you get your ducks in a row the fitting will be a none event.
Friscoboater
Re: fixing Transom
Check out my thread. I replaced my rotten transom, and then some.
