Re: OMC Cobra drive seized, now what?
I would not run it on muffs if you're unsure if it was filled properly. You can bump the engine, that should take care of any air bubbles. Better yet, drain the outdrive & refill it the proper way. Peace of mind.It never hurts to check (I learned that the hard way). If it shows low, you know you have an issue. If it shows full, nothing is lost (or guaranteed).
In order to prevent problems on the water, I suggest you start it on muffs at home and run it at idle speed until the engine warms up. The drive spins anytime the engine is running; the low speed operation should encourage any trapped air bubbles to rise to the top. After warming it up, turn it off and check the level again.
Be sure to tighten the dipstick plug properly after checking to ensure a good seal.
Good Luck!
