SnowHunter
Thread starter- Joined
- Apr 4, 2010
- 285
Hi Yall
New to the board. Just bout a 77 Bayliner Runaway tri-hull. We knew the floor needed to be checked, there was a corner hangin in the air I found while feelin for soft spots before purchase. For the price paid, I wasn't gonna complain about reflooring it.
Got it home, somewhat washed it up. Hubby got to piddlin with the motor (tryin to figure it out) and we got the inside ready to pull up and check out the floor.
Well..carpet came out, decent enough shape to reuse. Set that aside. We found that one of the prior owners just rough cut a piece, screwed it into the foam underneath (what good that did, I have NO clue
) and carpeted over. Ok, easy enough to remove and replace....
Out came the board...and beneath...
Flaky, wet, mushy stringers!
Suprisingly, the foam is 98% dry! (I did the nail check I read about here somewhere ) Just a bit wet on the exterior part.
Transom has a bad spot, gonna need to replace that.
Can't get underneath the front, gonna hafta take the top off for that. Dang rivets!!!
So our lil $350 boat gonna turn into our summer project!
I've gathered a good bit of info from this site in the last few days. This place is outstanding
There's no way to put this off and redneck rig it till fall. Just too much of a safety hazard IMO, and if the hull flexes bad with mushy stringers, then the whole things toast!
So what all else to I need to look for? I'm basically a newb when it comes to boats, but I have good fixin skills, and I'm handy, so that helps some
