greggles77
Thread starter- Joined
- Apr 6, 2010
- 11
Hello, I am new here (and to boating) so please bear with me if I posted this in the wrong place.
I have a 1966 Lark 40 hp model 40672B with an electric shift that on our last trip suddenly slips out of gear at just below halfway revs. The result was a very slow trip back obviously at only a few knots. until this time it has ran great considering its age. although I have only had it a few months and it hasn't had a service :redface:
I am wondering if it could be simply a lack of gear oil? I noticed it was possibly leaving a bit more than its normal slick in the water that day. I have also read on similar posts but not the same motor it could be:
*Wiring corrosion (Green or blue) - but not sure where these wires are?
*A damaged clutch dog - no idea what this is, I have the exploded gearbox diagram here that I purchased and I can't see it - is that the clutch spring?
*some other type of spring in the gearbox?
*a spun prop? not really sure what this means but seems common with this sort of problem..
*A damaged gear - although it does find reverse okay and as mentioned travels at low speed, so I am not sure about this.
I know a little about car mechanics but zero about outboards, but I am trying to get some ground knowledge. Any help you could give me would be appreciated. Here is a picture of the old tacker below:
Thank you.
P.S. I also have a spare one of these motors for parts if it helps I can change what I need once I know what it is!
Thank you.
