I'm a newbie to boating, but have auto mechanical experience.
I have a 17ft. '94 Thompson I/O and I'm getting fuel pouring out my drain plug when draining after a day on the water. I have had the marina look at it and they replaced the fuel tank sending unit, but it did not stop the leak. They are claiming it could cost me around a thousand to replace the tank (if that's it). I want to do it myself, but would like some advice first.
I'm assuming I'll have to take up the carpet and cut a hole in the floor board over the tank slightly larger than the tank itself. I don't want to go cutting into the floor board without some advice. I'm open to any and all suggestions/tech tips, etc.
The marina and I think the tank may have worn a slight hole in it by wear. Perhaps it's gotten a bit loose and is moving slightly in place and worn a tiny hole in it. Is this probable and does that happen often?
I'd appreciate help.
Thanks!
Thanks!
