trevtt600
Thread starter- Joined
- May 17, 2009
- 80
I purchased a used 3.0 to replace mine with a cracked block (motor has a 30 day warranty). I ran it for the first time today out of the boat on the ground. After i ran for about 5 minutes or so, i shut it off, and removed the valve cover oil cap. I notice a water/oil milky mixture in the valve cover. I pulled the cover off because i am swapping it out with my old one, and there was a decent amount of milky substance in there. Is this something to be concerned about? Or since the motor probably has not been ran for over a year or more, is this just moisture that has been sitting in the motor for so long. Do i need to run it longer and see if my oil gets milky also? I installed my old manifold off old engine with a new gasket also. Pressure tested the manifold as per the instructions on this site with no leaks. What are your thoughts?
