Hydraulic Trim hose... O ring or not?
Xesvuli420
Had a badly leaking Cylinder hose. Previous owner wrapped it with Ducting tape (not Duct tape) and 4 small clamps tightened all around the leak. It worked pretty nicely except the fact that water could get in and destroy my pump, so I decided to fix it NOW.
I had to remove the stern to get it off. A new one is being made as we speak.
Keep in mind the hose ONLY leaked at the rupture, NOT AT THE CONNECTIONS.
When I unscrewed it from the cylinder, as well as the junction block, NO O-ring was on either side. When I took it to a local Hose and Hydraulic shop, the guy said most likely it was supposed to have one on each end. He had never seen one used without a O-ring, but then again he wasn't sure.
PLEASE PLEASE PLEASE
Only answer this if you are 100% confident, I don't want to have to remove the stern again just to remove (or add) a couple O-rings!
I attached a picture to represent what I'm talking about... It would have been much easier to just post a picture, but the line is in the shop, so oh well, ART TIME!
What do you guys think?
Thanks
Xesvuli420
Re: Hydraulic Trim hose... O ring or not?
Sure does... Wonder why it didn't leak... unless the o rings are stuck up in there... hmmm
Here is the BRP online catalog. Look up your engine and see if it has seals or not. If it didn't have any, it probably doesn't use them, or it would have leaked.
http://epc.brp.com/SiteMods/BRP_Pub...efault.aspx?brands=ej&lang=E&brands=ej&lang=E
Didn't see OMC, I know its not OMC anymore, I think it became evinrude, but I can't remember.. Either way, both show Orings
Thanks guys!
Don S
No, they are not OMC, but if you click on sterndrives under products, it will take you to the catalogs.
