Metallic clunking sounds when accelerating
HerbieJ
I bought a used 1994 Mercury Tracker, 3 cyl. 60 hp motor last November. Oil injection pump has been removed. I've invested about $400 in it, adding / replacing little things worn or missing. My efforts have included rebuilding the three carbs, replacing the spark plugs and wires, and verifying the timing was correct. The motor starts and runs, but with a rough idle that carb adjustments don't correct. Big problem though is, when motor is accelerated to approx. half idle, I can hear metallic clunking sounds coming from it, especially when I back off the throttle. There is no apparent engine miss or decrease in rpms accompanying these sounds, but I'm only running the motor in a barrel w/o a prop. This is my first outboard motor and, while I?m familiar with car engines, a two-stroke is new to me. I'm really concerned over the metallic clunking noises I'm hearing though. Compression on all three cylinders is very close to 110. What do you think my problem might be?
j_martin
Re: Metallic clunking sounds when accelerating
Have you looked into the LU. The noise might even be normal with no load on it. With muffs on and a prop, at least you have an inertial load on it.
The rough idle could be one of 3 things.
1. You thought you fixed the carbs, but didn't.
2. bleed valves and lines
3. reeds
hope it helps
John
79Merc80
Could be the pressure plate in the flywheel. Lightly tap on it with a hammer. If it rattles, then the plate is cracked. Had that happen on a 69 Merc 1250. Thought I was throwing a rod or something.
j_martin
Correct description is flex plate. :D
hope it helps
John
sschefer
Is there lube in the lower unit?
