its a 1989 johnson wont start
starcraftstriper
THe motor turns over and the fly wheel spins but it wont engage and start. What could be the problem what should i look at? another question when i pump the primer bulb and make it tight gas starts coming out the carb where a little hole with a screen on it why is this? i am new at this and need help
Lion hunter
Re: 1998 johnson wont start
No really understanding what you mean by won't engage. If the starter gear engages the flywheel and the flywheel turns it is engaged. You will need to check that you have spark and fuel from there. Read this entire file:
http://forums.iboats.com/showthread.php?t=299680
I assume that you bought the motor in your other post. Did you check compression? As far as fuel coming out , you should also read the motor sitting for 2 years link and follow that. Good luck and you will find good help here but the link above is probably the most important to read and follow.
starcraftstriper
Lion Hunter, I bought the motor but it was a big down pour and the guy said if it dosent run bring it back we made it legal and stuff. But i will read that and i was so confused i didnt mean to put engage.
90 % of the time, if the starter does not engage, the problem is poor current. weak battery, dirty connections, both battery terminals, all connections on starter solenoid, and starter, and the ground connection to the block.
fuel leak is the float needle in the carbs is not closing, and stopping the flow of fuel. the screen vent, is the carb overflow.
i agree, top secret file.
starcraftstriper
Yea so how do i fix the float needle? should it start without fixing the needle tash? Just to see if it runs and yea im sure it my connection now that ive read.
Lion hunter
Compression check is 1st in order to see if you want to put money in the motor. If the compression checks out then I would move on to check for spark. If there is spark, then clean (clean clean clean clean then clean again) and rebuild the carbs. A rebuild kit will probably run you 25-30. Put some new plugs in just to be safe, fill the lower unit and then start. Pretty much everything you need to know to do it is in the top secret file.
starcraftstriper
Im checking compression and posting it later. It was just tuned they said and it has brand new spark plugs and carb was rebuilt.
Lion hunter
The big issue is the last time it was ran. Read the section on ethanol poisoning. It can reek havoc even on a new rebuild if it sat for too many years.
starcraftstriper
Yea i read that i read that whole file.
